- Dec 22, 2012
- 328
What advice were they?
As long as it is square to the material, extended just long enough to make the cut through, and at or slightly below the material's centerline, it works very well.
Tom
Thank you. What is a T bottom blade?
Like this.
http://www.ebay.co.uk/itm/5-16-Sq-S...Home_Garden_PowerTools_SM&hash=item4d272689f6
The top of the blade is thicker than the bottom, and this particular one has the grove in the top karl & John Mentioned. This one is 2mm wide, you might be able to find a 1.5mm or 1mm wide version. The narrowest one I listed above was only 1mm wide.
Aside from the tools merits and e-bay auction where the price will undoubtedly rise, I have an aversion to the second tool based on price. The auction is at 6.60 pounds / $10.10 versus 118.50 pounds / $181.30 or 18x the price. Certainly the first is under priced but the second seems overpriced.
Caster
That's great! Thank you. I shall place an order!
Can Parting tools be used to turn my rod as well? With my intended purpose of creating a channel (maybe 1mm deep using the parting tool), can I then widen that channel across to maybe around 5mm using just the parting tool?
Like this.
I've just been checking - this is too big for my tool holder
I've contacted the seller to see if he has small ones
I'll have to recheck. When I checked the other day, the blade holder looked to be too big for my toolpost to fit... I could be wrong and I hope I am coz this looks good!how so? the shank is 5/16", that's thinner than your current 10mm tool.
