- Apr 4, 2013
- 884
The LED on the scales that I have light up when the scale is aligned correctly and is off otherwise (when the scale is powered up).
Just to make sure, can you confirm the following:
1. The board is powering up (green LED on, blue LED blinking)
2. You can connect to it via the tablet (TouchDRO shows up in the list of devices and the app can connect and stay connected)
3. When you move the scales, the display in the app is not changing
4. This happens on all 4 inputs (W needs to be enabled in the settings to be displayed or added to another reading)
5. Voltage between the Vcc pin and Ground pin is around 5V (+/- a few % is not a big deal) when all scales are disconnected
6. Voltage stays the same when a scale is connected (all four lines are wired in parallel, so you can plug in X and measure Y, for example)
7. Voltage between A, B, A' and B' is around 1.75V +/- 0.1V when no scales are connected
8. When a scale is connected, you see voltage close to 0V or 5V (depends on the current position, should change when the scale is moved)
