Thats the one Ken, forget the actual price, with shipping and duties and exchange it was just under $150 cdn.
Yup! I'm loving it so far.
Originally, I had a Yihao display on both machines. Awhile back I decided to upgrade my lathes x axis scale to a Sino low profile 1 micron scale. But, the scale ended up being rs422 push/pull quadrature, and my Yihao display wouldn't read it.
None of the other half dozen Chinese displays I had in my junk cabinet would read the Sino scale either, except the ToAuto, when I re-pinned its 0v, 5v A and B reads to the appropriate pins. And that display had non-functional axis zero keys, so it was out.
I ended up with an Amazon ToAuto TTL 4 wire scale on my z, and a Sino RS422 9 wire scale on my X.
I contacted DRO Pros, and they mentioned that this Ditron D80 would read both open ended TTL and RS422 push/pull quadrature signals simultaneously. So, I ordered it, swapped in their glass scale ribbons, and re-pinned my ToAuto scales db9 plug to match the Ditron scale. It's been running great so far.
I think there's a bit of confusion amongst Chinese manufacturers and sellers about the definition of TTL RS422. They seem to have seperate the two, and are calling push/pull TTL signal rs422, and the open ended signals TTL. Once I figured this out, it was alot easier to figure out which scales would run on which displays.
It was an educational experience. All my experimenting resulted in a pile of cheap Chinese displays and scales. Ive cut various scales down to custom sizes, swapped and rewired the read heads and displays internal connections. Most of them, I ended up rewiring into functional kits and giving away to friends. I still have 3 displays and 2-1/2 scales for spare parts/backup units.
