The reason 100/127 gears are used to convert from inch to metric is there are 25.4 mm to the inch 127*2=254! Some small lathes don't have room for a 127 tooth gear so they use something that comes very close and is smaller. There isn't a lot of force on change gears so dense plastic ones should last a long time for hobby use. And you can always print another one.
I wouldn't worry about getting some exact feed match for turning. Experiment and see what works for you. I tend to hog material until I'm within .020± Then power feed rather slow for a good finish dividing the remaining into 2 = passes. The first pass confirms I'm going to get the finish I want and will be reproduced on the last pass. Gives me a chance to make a correction if needed.
3D-printed change gears for EMCO Compact 5 latheEMCO compact 5 feed mechanism comes with 6 change gears(for common metric threads): 20, 25, 50 and 3x 60 teethFor uncommon threads or imperial threads additional change gears are needed:26, 30, 34, 35, 36, 72 and 40 teethWhile you can buy them from...
IMO printed change gears are the way to go and maybe think about an ELS for the future.
i have steel gears and most all of the ones i need but plan to 3D print anything i need in the future and or add an ELS.
Been really pleased with my ELS. Has saved a lot of "hassle" due to gear changing and clean up. Not that any of that was difficult, but the gear change process seemed to interrupt my thoughts. Find it a lot more convenient now. Tap the touch panel and set the feed or threading parameters. Done in less than 15 seconds. I rolled my own, but I think ELS in general is a good thing.
