Which Boring Bar?
I use these holders and inserts in a semi -production shop with 1144 and 4140 steel - no issues. Buy the whole set or as needed 10mm or 12mm shafts: (and get a box of each type of insert)
I now only use HSS for form tools or special setups
When I need to bore less than 3/8" I use a 4 or 5mm carbide endmill
I've had pretty good luck with the cheap braised carbide boring bars. They work really well on aluminum but have to take pretty light cuts on steel
Sent from my SM-G920P using Tapatalk
Used it to make a bearing removal/install tool and to make a new bearing
I'm not really disagreeing with anyone because I don't enough.
