Where do I start
don't break the third commandment
"thou shall not mill on a drill press!"
you sound like you have a good handle on metal work so you should be fine with a bigger lathe. you get much more bang for your buck with larger lathes.
You're part way there in your thinking. You can add a vise or work-holder to the cross-slide on a lathe and mill with that.
Drill presses are not rigid enough. Frightening things can happen if you try to mill on one, usually breaking the endmill.
If your milling needs are limited to that single slot, consider a punch. Fast, clean, and easy. Very consistent as well.
If you are not in a hurry, I would snoop around for used American or Euro machines. I don't know what the market is like in MO, but in my part of the country (CA) manual (i.e. not CNC) machine prices are falling. Also, if you have room, bigger machines are generally cheaper than smaller ones. Many used machines will come with tooling that would cost you a grand or so to buy separately. I started with an HF 7x10, but it was so crappy to use, that I really didn't feel it deserved time and energy to improve it (though there are websites devoted to people doing amazing things with these machines and 9x20 lathes). I was able to sell it at not much of a loss, but I viewed it as waste of time.
I also would think twice about the Granite or any of those combo machines. Setups are often a pain on those, which for me would probably prevent me from starting a project. You can get used American separates for similar money. Even separate Chinese machines, like a 9x20 Lathe and 6x26 mill, would be far better than a 3 in 1, unless you don't have space.
Know very little about machining but have a long standing interest. Reading a lot, watching YouTube vids,studying machines. Lots of questions.....
should I start off with an inexpensive mini or???
the smithy granite looks great but too much money
bolton looks good, price is right but are they as good as they look.
Are the combo machines good or should I go for separate lathe, mill...
thanks all
ron
A personal view from someone who has just sold a combination to purchase a separate mill and lathe. The two biggest pain points were the set up time. It always seemed that the majority of the shop time was taken changing from one to the other and back. The second was the compromise on capability, especially on the mill. Not rigid enough for anything but very light cuts.
tony... not sure what you mean... this is 3/16" steel never tried to punch thru this heavy material... i will probable end up drilling out the hole than filing the details. it is an oval hole to fit a pipe cut to the right angle
ron
Another thing to consider
The larger the machine the harder it is to break……
And the more expensive the repair parts become. Bigger machine equal bigger bucks when you strip a gear or crash the tool into the chuck. I have a three in one and seperate machines and I prefer the different machines because I seldom complete any project start to finish in one sitting, so theoretically I can have up to 4 projects going at once. Just my .02.... Welcome to our little club and welcome to the addiction. There is no cure, so surrender gracefully and get you wallet loaded into the web for tool and trinket purchases that are coming frequently in the next little bit...
Bob
