Thank you.
Yendor,
I am not cutting threads in both directions. The last picture I posted was done cutting thread in one direction - towards the spindle. I just kept the half nut engaged, turned off the motor, back out the cutter, reversed the motor to move the carriage back to the right, then made the 2nd pass.
Phil,
Unfortunately the only documents I have is just a few pages on the controls and starting up the lathe. I have a TravAdial blocking any view of the half nuts. It looks like I need to remove the bracket holding the lead screw and feed rod, and TravAdial. and slide the carriage all the way to the right to even inspect the half nuts. I don't know if I were to replace the half nuts that I have to completely remove the carriage out of the lathe. I've never been this road before.
Andre,
I do not know and could not tell whether the half nut lever backs out or not, I'll have to make some runs and observe. One thing I never noticed before and was not looking for it before either, but the lead screw bends down every time I push the half nut lever down to engage.
Do you guys know if the half nuts on these 70s era Taiwanese lathes are brazed on, or soldered on to their housing? Next question, if I were to replace the half nuts and no commercial ones are available, do y'all know who could machine or rebuild mine?
I dread the thought of tearing the carriage apart.
