What factors do you use when deciding on using coolant or not and type of coolant ?
Wondering what types of coolants I should be aquiring, when to use, and how I should be using them.
I meant to answer these questions and got caught up in the flood coolant thing.
Other than brass, bronze or cast iron I always use cutting fluid on the lathe or mill. This is not just to lubricate. It also changes the way the chip deforms at the point of cut. The best example of this is when boring. A good cutting fluid can change a chip from long, stringy chips to nicely coiled ones that self-eject from the bore. Cutting fluid also reduces the formation of a built up edge (BUE), especially with Aluminum. Your finish will also be much better with cutting fluid with most materials.
If you use carbide tools it is best to decide on whether or not to use cutting fluid from the beginning. Don't go without it and then shoot a bunch of it on a finish pass - you can cause thermal cracks on the insert. This is especially true when boring.
As to which types of cutting fluids to get, there are as many opinions on this as there are cutting fluids. I'll give you my preferences:
- Aluminum: WD-40 for general work, A-9 for fine finishes or when I need to take a whisper cut and need superior lubrication.
- Steel: Tapmatic #1 Gold. This stuff is readily available and works well. I especially like it for harder materials like 1144, 4140 and tool steels - good finish.
- Stainless: I just use Sulfer-based cutting oil. I hate the smell but I like the finish, especially when threading and knurling.
- Brass, bronze, cast iron: None
Whatever you use, be sure you have good ventilation. Breathing in the smoke from any of these fluids is not good for you. Remember that the chemicals from any fluid may be absorbed through the skin so nitrile gloves are always a good idea. Safety glasses are also important - an eyeful of cutting fluid will teach you the truth of this.
You cannot argue the value of temperature reduction, chip clearance and improved finishes with flood coolant - it will always be better than a brush. You need to decide for yourself if the expense and clean up hassles are worth it for the work you do.
