- Jun 7, 2013
- 10,450
Another note on solid centers; The center that is used in the headstock has a vee slot turned in the shank on the taper that fits the spindle taper, this is to signify that it is soft at the point; this is so that it may be trued up by re-cutting if it runs out. The tailstock center is hardened and has no such slot and must be ground to true it up, although carbide tools of a harder grade, such as Kennametal K-6 will cut most hard parts.
