- Dec 25, 2011
- 599
I do almost all of my drilling on a drill press. I have 4 of them. A 16" and an 18" swing and two around an 8" or 10" swing. A pair was in my garage shop in town and a pair in my basement wood shop. Since selling our in town shop I built a new shop at home to work on my cars and play with my toys in the machine shop. I have a 6" vice on the 18" almost all the time bolted loosely so I can shift it around as well the table rotates so I can quickly line it up. Once lined up I tighten my vice jaws. If it is a long piece and the drill bit large I try to also let the stock rest against the column, other times when the drill is small I hang onto the vice screw to hold it. I like the small drill press as it has higher speeds and use it when drilling holes under 3/16" and use a small vice for small parts or just hold the piece by hand on the long pieces. Of course it also only has a 1/4 hp motor.
However when drilling a large hole or in hard material I find the drill press tables flexes too much to get a good square to perpendicular hole or when drilling through both sides of square tubing when a pin must go through to hold an inner part I switch to my mill/drill. I still have the quick quill available like with the drill press but there is no flex between the head and the table. This makes all my holes line up. So I wouldn't be without either of those.
The biggest scare I ever had was with a high torque hand held 1/2" drill. I had to drill a centre hole in a car leaf spring and had the spring clamped fairly secure in the bench vice. (This was before I ever had a drill press) The drill had a little button in the handle by the trigger that you could lock the trigger on with. Well the hole had to be 7/16" so the bit was quite strong and when it grabbed my grip pressed the little button and could not stop the motor. The spring pulled out of the vice and I had to let her go. It banged around on the bench until it pulled the plug out. Of course this happens in a mere second. The first thing I did was nip that little button of and that is how it still is after more than 40 years.
Nick
That wouldn't be a Milwaukee drill by chance--I have one and it CAN hurt you. Don't ask how I know that!!!
