- Oct 4, 2011
- 727
OK, imagine the circumference of the shaft flattened out. Now at 1725 RPM, how many feet per second (or inches, or MM or CM, as you wish) does it travel? Calculate how far apart the marks need to be to represent 1/60th of a second. Now convert it (mentally) back to a circumference, and you know how far apart to mark the shaft. Of course, there are limits to consider, a 1/4" shaft may not be "long" enough to mark, as the circumference may be shorter than the distance traveled in 1/60th of a second. I haven't done this kind of tach work in ages, but it does work. The 60Hz (or 50 in places) is generally very accurate. It's what keeps out plug-in clocks running
Here is a page that kind of goes with what Tony is saying. I used this method years ago for a project and it worked well.
http://www.sherline.com/rpmgage.pdf
Jeff
