That seems cover just about every chuck scenario... but I'm still foggy on the real value of the set-true (or adjustable, etc...) 3 jaw chuck.I am an advocate of getting a good set-true style 3J scroll, a slightly larger 4J independent for bigger/rougher/odd shaped stock, and a quality collet type chuck for smaller round stock. QMT/PM carries these chucks in mid-priced range versions, and I feel they offer very good performance to price ratio
Is this a correct statement? The primary benefit is when you plan to chuck the same sized parts and or need to flip a part and keep it concentric. The second you open or close the jaws too much for a larger or smaller part, you lose the benefit of an adjustable (scroll type) 3 jaw chuck where TIR was all but removed... and you are back to the characteristics of a standard, non adjustable 3 jaw chuck.
If I'm tracking correctly, what's the tolerance for "same sized parts" in an adjustable 3 jaw chuck. In order to keep TIR very low between chucking different parts all have to be within a few thousandths? Or is it more like 1/2"?
Now, I guess there's no harm (other than higher cost) in getting an adjustable 3 jaw chuck. I'd assume the 6" 3 jaw adjustable chuck PM sells is of much higher quality than the economy 3 jaw scroll that's coming with my PM-1236T. But when I decide to upgrade/add to my chuck collection (a future purchase), I wonder if spending more on a higher end 3 jaw and not so concerned with higher end 4 jaw (as I have yet to use one, though, one day I will) is good logic.
