Some background info:
Current shop service is maxed out so only have 120 volt/20 amp outlets available. In order to get more 220 outlets I would need to have 300 yards of new cable trenched in and a 200 amp service installed. Not on my agenda due to cost. Only 220 outlet is dedicated in an area far away from where I would place a mill and/or lathe and is in the welder/grinder area of my shop.
Even though most people feel a lathe should be the first machine tool purchase the projects I have slated are primarily geared for a milling machine. One example is a square coupler, 1” hole bored through it, with a 1/4” key way and 2 threaded holes for set screws. It connects a hydraulic motor to a shaft that turns a canvas roller on a swather(farm equipment).
Looking a mills I have narrowed it down to the PM 727V and the PM 728VT. I will be primarily working with steel and only occasionally aluminum. Torn between the better fit and finish of 728 Taiwan machine or more heft/powerful gear head Chinese 727.
When finances allow for lathe purchase looking at PM 1228VF-LB. Would love to hear any feedback on choices or other alternatives.
