- May 4, 2015
- 3,574
You could always double stack the kv at the cost of blum . It's done on snap on boxes at least mine.
Look for some full extension ball bearing sides. The cheapies work well and generally rated close to 100#. The Blum brand allows up to 150# and you can get soft self closing . If you have angle iron cabinet you'll spend some time mounting the slides. TomI'm looking at making some drawers for my lathe table. It is angle iron , Base is 19 inches front to back, with 36 1/2 inches between the inside of angle iron,
If needed I could put something in the middle and make drawers on each side, instead of having such long drawers. But what would be the best type or way to make drawer slides for this. Had though about cutting down some old rack slides from old servers but after having them in the shop for a while notices the grid, dirt, swarf etc, found they do not move all that good. So now I'm looking for suggestions. Figure to put chucks and other stuff in them so they could require a heavy load. Suggestions appreciated.
Attached is a simple drawing.
Server rack slides is what I've been using the last two decades.I'm a little hesitant about the open ball type slides as the ones I was going to redo to use, came out of a server room, They would have held plenty of weight, but the grit and swarf would make them a pain all the time. It would prob cause them to fail quickly. Thus I think the sealed bearing type may be the way to go. I know Blum as have use them and they are expensive, looked at the others but all look like stuff could get in quickly since this is an open sided frame and I do not really want to enclose at this time.
