I prefer to braze cast iron with oxy/acet. torch. I have done lots of it over the years; for simple small parts, preheat beyond what the torch does is not much necessary. I first grind a vee on the broken halves, on both sides if possible, leaving a unground land to align the parts with respect to each other; then I coat the ground surfaces with silver solder flux to protect them from oxidation when heating and brazing. I use ordinary brazing rod such as welding supply business sell; now the most important part --- most all brazing fluxes, even those purporting to be good on cast iron, are not so good at all; I use Anti Borax EZ #3, it is superior to all others. Also, take care not to overheat the base metal so that it turns black; if it does, the braze will not adhere well. If it does happen, stop, let cool and regrind to bright metal, re flux and start over. The right heat is when the braze metal wets out on the base metal, like regular solder does.
