The ones under the “?” are (top to bottom):
Chamfer
External threading
External threading
Also:
I’m very glad to see that you have them all oriented correctly.
I do consider “LH Turning Tool” and “Facing Tool” to be synonymous. Along these lines, it is very rare when I need to turn away from the headstock (LH turning). It is even more rare when I need to face radially outward.
Very nearly 100% of the time, I face from the outside in; if the cutting tool is not centered perfectly, this results in a nub. If the nub has perfectly straight sides, your tool is too low. If the nub has a rounded profile, your tool is set too high.
