- Jul 26, 2011
- 4,139
I made a brass dividing set for my 6" rotary table years ago. I found it quite easy to step off the numbers of holes with dividers. After a few adjustments,each row of holes was accurately stepped off. Then,carefully ***** punched. I even used a pump drill to start each hole by hand. The old fashioned pump drill can very accurately drill holes. It is slow,and you can tip it some to bring holes back on center. Later,I drilled and beveled the holes deeper with a small center drill in the drill press.
At 90 to 1,any tiny discrepancy would be vastly reduced on your project,though I could not see any lack of accuracy on my dividing plate.
Early Dutch clock makers divided gears entirely by hand with a trick: They made a much larger circle with the gear fixed to its center. Then,they'd step off the spaces with dividers. When properly stepped,they took the dividers and swung the stepped off spaces down to scribe them on the O.D. of the gear. This use of a much larger plate enabled them to further reduce inaccuracies in the smaller gear.
Later on,dividing engines came along. But,they were expensive and many a clock was still made the old way by hand dividing.
