Did you mess around with feeds and speeds?
From my rank amateur view it looks like it may have been too fast for HSS and too slow for carbide.
But it also could be crap steel that won't give a really good finish.
A quick test for carbon content is to do a spark test. There are lots of videos out there if you are not familiar. Basically the higher carbon steels will throw sparks differently than low carbon steels. I sometimes do a comparison to something that is a known steel or at least a known type.
Touch the test piece to a running grinder and observe the sparks. How many and the color. Also watch to see how they give off secondary sparks as they die out. Then do the same thing with something you know is hard, like a drill bit or tap. I keep a couple of broken ones near the grinder just for this purpose. For me this works pretty well on plain carbon steels but gets a little iffy with aloys.
Another test would be to saw off a few slices maybe an 1/8" thick and heat treat them. Try different heat temps from cherry red to bright white before quenching. Once cool put the disk in a vise and hit it with a hammer to see if it bends or snaps. Lower carbon steels will be more likely to bend and higher ones will be hard and have a tendency to snap.
All this is pretty crude analysis but sometimes it is all us hobby guys have the ability to do.
