P
pollardd
Forum Guest
Register Today
Hi Wes,
The A in AXA refers to the size. You should be able to google the specs although they can be a bit confusing.
The measurement you will need to know is from the top of your compound slide (with the old existing tool post off) to the centre line of the machine.
The tool post specs normally have a range of distances that each tool post can manage.
The BXA is the next bigger size. This is the one I bought (currently in shipping)
I'm hoping all my calculations were correct and that it will fit my 10" Atlas.
It will allow me to use up to 16mm tools. (5/8")
My plan is to use 1/2" HSS and grind them up my self.
Someone else here used a 4 Jaw Chuck to turn down the T nut blank.
The forum thread was promoted to an "Article" so you should be able to find it.
They did a nice step by step guide with photos.
Guy's Round and Ground solution looks pretty neat as well.
But both solutions still need you to be able to hold a cutting tool somehow.
I have an old 4 sided square tool post with most of the square head tool clamping bolts stripped out (by previous owner)
It has two left, I'm hoping it will hang to do one last job. "Make my new T slot bolt:
I have the rocker holder thing but no tool holders to go in it.
My old apprentice master would have said....
"You got a file haven't you"
He even made us make things with a cold chisel before we were allowed to use the machines.
"One day you won't have a mill and you will be glad you know how to use a chisel"
Old bastard was probably right
Hope this helps
David
Hope this helps
David
