- Dec 27, 2014
- 4,087
No. 10, at .190 would work well with a 3/16 (.1875) rod.
This is why we have machine tools
So besides #5 (1/8" rod) nothing under 1/4" seems to be a standard off-the-shelf rod size. How convenient . And #5 isn't a very common size.
Brockwood, you are referring to a Tailstock Die Holder - useful tool.
This is an old thread but on the off chance that some new guy will see it, I'm attaching the best chart I've seen for sizing the rod before screw cutting or using a die. You need to determine the class of fit because this determines the rod size used before cutting the thread. Note that a class 2a is a looser fit than a 3a and the starting diameter ranges are tighter. The stock is turned to the OD limits for the class you need and this allows you to obtain the needed pitch diameter range you need for that fit.
For example, for a class 2a, 1/4-20 external thread, you would turn the work to a diameter between 0.2489 to 0.2408. Then you put a 30 degree chamfer on the end and thread it or screw cut it. Then you check with three wires or a pitch micrometer to be sure your pitch diameter is between 0.2164 and 0.2127" and this should allow that work piece to fit any class 2b nut.
