I got this machine base from a Craigslist type deal. I have a weakness for overbuilt workshop equipment, but this takes the cake.
It seems to be 1/4” steel plate all around.
The plate on the top is about 19.5” wide, 22.5” deep and half an inch thick.
The base has ribs running front to back, for stiffness. The “feet” are just 1-inch hex bolts. the height is 31.5” without feet, or up to 36” with the current hex bolts.
I can’t easily move it without a pallet jack, which I don’t have (yet) but I suppose I could set it down on some pipes and shove it around like stonehenge.
My shop is 30x30, with an almost-90-inch ceiling and two bay doors.
The obvious thing to do with it is to use it as the base of a bed mill like the PM-833, which would *just* clear my ceiling with the base sitting down on the floor. This would be about 3x the weight of the base that PM sells for the 833, certainly not a *bad* thing, but would this help with rigidity in a meaningful way? It seems like the weak point of bed mills is the column and head…maybe all this weight will cut down on resonances. Maybe it just helps me move it around when needed: I can use the threads in the base to jack it up and get pallet forks under it.
I can also imagine mounting some manual tools with long handles, like an arbor press, a pipe bender or a throatless shear.
Somebody suggested using it for a welding table…I guess I would put a 2’x4’ top on it, maybe 3/16” plate, stiffened with angle iron. I suppose it would be cool to have a “pedestal” welding table, with notlegs getting in the way of whatever I’m trying to clamp.
Let me know what you think I should do! And if you have a sense of what this base was designed to do, let me know! I’m curious.
