- May 8, 2016
- 20
You can add a similar position only DRO to any machine for about $130 using igaging parts. You can upgrade that to a touchdro with a $70 board and an Android tablet or even an old phone. You can also buy a full DRO from aliexpress for about $200.
My budget was 3k as well. I was a little hung up on DRO as well. I decided I can add it later and use magnetic mounted dial indicators for now. And with shipping I went over $98. It will take some time as the one I chose is backordered, so I'm picking up bits here and there to fill in. Primarily ebay. I expect I'll spend a few hundred more before I make chips, but I think overall I will enjoy the machine more.
A few things I was convinced by..
Full variable speed.
Power cross feed.
Included QCTP. Note that some machines can't just bolt one on...
D1-4 chuck, very compatible. Easy to get things like a collet chuck later if I want to.
1.5" bore. I have some projects in mind right now that will use it. It sounds like some of yours might as well.
Wider bed, rigidity is increased, less tool chatter, flex, etc.
Hardened ways. More durable.
Included tooling. Things like steady and follow rests, 4 jaw, QCTP, face plate..
Comparing reviews between Grizzly and PM users.
As for what you need to make chips, some HSS bits, or carbide. A couple dial indicators and a magnetic base. A tailstock drill chuck. Some center drills. Calipers and micrometer. Oil for the ways, cutting etc.. I'm going with cheaper indicators to start, tests show them to be very accurate, and it's always nice to have some you don't mind getting beat up. I'll add some nice ones later. I'm sure I'll break at least one, I'd rather it be a $15 indicator than a $150 unit.
Just putting my reasoning out there from a fellow newbie. I don't know that my way is best, but it makes sense to me. Whatever you get, use the hell out of it and make cool stuff. Then post pics.
What did you end up getting? After areading all the posts on here, I am now leaning towards the PM-1030V. The QCTP is around $200, and then the variable speed also. That makes up for the $400.
http://www.precisionmatthews.com/shop/pm-1022v-pm-1030v/
I selected the 1030V, then the addons I selected, The Stand, The drill chuck for the tailstock, The AXA master turning/boring set, and the 1/2" internal/external threading set.
Any other tools you would recommend?
I like the idea of using magnetic calipers for a temp, dro solution. I know I will need some center drills. Also Some cutoff tools. Cutting oil too. Can't think of anything else right now.
