This is the most important thing when using masks. A standard breathing apparatus in the service was positive pressure with a demand valve so when you took your first breath, it would positively pressurize the mask so any areas that didn't seal lost air but nothing could flow in. With a non-positive pressurized filter mask, you need to ensure a good seal against the skin otherwise when you draw a breath, you will be pulling un-filtered air.
A mask needs to be part of a larger safety and health philosophy though. Wearing a mask while grinding and painting, then not wearing it when you sweep or blow out the workshop is counterproductive. Keeping a clean, uncluttered workshop means it's easier to control dust and wipe surfaces clean. This is often a problem because those who use masks often store them in the open, where dust from sweeping settles in the mask, rendering the filter useless.
Paul.
