- Oct 29, 2012
- 1,387
Is it heat buildup in the compressor head? Availability of lubricant to the crank? Other?
Let me explain the reason for my question. Compressors typically run off a simple pressure switch; on or off, 60Hz, fixed speed, fixed displacement. The CFM at 40psi and the CFM at 90 psi are usually pretty close, at least for those which use an induction motor.
For example a 5hp compressor, when you first turn it on, starts spinning at a more-or-less fixed speed, delivering a more-or-less fixed CFM, but consuming much less than 5hp. The amount of power consumed begins to climb as pressure climbs, and probably don't utilize all 5HP until right before the pressure switch drops out. The rest of the time before that, the true potential of that big motor is never utilized.
BUT if I were to put that motor on a VFD and (assuming motor is 3ph vector duty, with bearings rated for it) set the max frequency output to say 240Hz instead of 60Hz, and put the drive in torque mode instead of speed mode, then:
1. as soon as you turn on the compressor it ramps up to 4x the normal speed.
2. As pressure starts to build and the motor starts to see some resistance, it starts to slow down. This point at which it starts to slow down is the point at which it hits its 5hp limit, which it will stay at for the remainder of the cycle.
3. As the pressure continues to build, the speed continues to drop, until (assuming I've got all the parameters set correctly) it should fall just down to 60Hz right before the pressure switch cuts it off.
So the result is:
1. a much better utilization of the motor
2. A much faster charge-up time
3. Higher CFM (in fact much higher than nameplate rated) at lower pressures (and nameplate rated CFM at nameplate rated max pressure) instead of a more-or-less constant CFM.
Instead of a linear HP graph starting at zero and ending at 5hp right before pressure switch cutoff, we see a fast climb to 5hp and a plateau at 5hp, continuing until pressure switch cutoff.
So that's what leads me to my question. Is it safe to 4x overspeed a compressor head when output pressure is below 1/4 of max pressure? Is it cooling that's the issue? Because if it is, then I suspect it's a non-issue. The heat from compression at lower pressures will be less than at max pressure (right?) And in addition the cooling fan/pulley will be spinning so much faster than normal, that if anything, I suspect the compressor might actually experience cooler operating temps than normal.
But if the concern is oil starvation then I probably need to be daydreaming of something else entirely. I don't know if there's anything that can be done about that. There's probably also more important questions that I don't know enough to ask. So I petition this panel of online experts. What say you?
So the result is:
