- Nov 21, 2015
- 56
Hi sorcerxl, I started out with a similar sort of lathe a few years ago. It worked for me but I spent quite a bit of time making it "better", doing a lot of the mods that appear on various websites (camlock for the tailstock, tapered gibs for the carriage, headstock bearings replaced, cover the back of the apron to stop chip ingress, quick change toolpost etc. etc) I learned a lot from playing with this lathe (mine's a Sieg SC2) and I made a good number of small parts on it but have since upgraded to a larger used lathe (I'm not in the US either so don't have access to that goldmine of American iron). I used the Sieg to make replacement parts for my "new" lathe, a Harrison M300, as I stripped it down, cleaned it and replaced worn out bits. I still have the Sieg but don't use it much now as it's not as convenient or capable as the M300.
I don't think I would have had as much knowledge or confidence to tackle renovating the M300 had I not had the Sieg first. I bought from a reputable supplier in the UK so had some comeback in the event of quality issues, but mine wasn't too bad. I needed to upgrade when I started getting close to the capacity of the lathe (it ma be a 7" swing but you'll struggle to turn parts above half that diameter - not to say it can't be done).
Don't forget that spending on the lathe is only a part of the total outlay. There's materials, tools, a QCTP, indicators, chucks etc etc that can cost in total more than the lathe, but you don't need them all at once.
