@Weldingrod1
Slow and steady. I read somewhere that when Ford made the cross shaft it was straight when the ends were turned. Then the shaft was bent as you see in the photos.
The center holes in the ends of the shaft were buggered up such that the shaft would not turn concentric when chucked up on a live center in the tailstock.
I turned an aluminum adapter piece that had a 75 degree concave cone on one face and a center point hole on the opposite face. That adapter was placed between the tailstock live center and the shaft end. This allowed me to hold the the the loose end of the shaft at the tailstock and to adjust the shaft so it ran true in the lathe.
I had a chuck stop on the opposite end so the shaft would not slip back into the chuck jaws.
Then I just went at very slow RPM and took light cuts.
It worked and I was able to get both ends of the shaft turned to proper dimension.
Rick
