"What Is This Thing?" Running Thread
Thanks Rich and Jim, you guys nailed it.
-brino
This one has me puzzled. It was in one of the boxes of change gears and/or tooling that came with my lathe.
Reminds me of a hypodermic needle, but on an alarming scale.
It looks like a tool for inserting pins in mil spec connectors. You solder the wire into the pin then the wire sits in the groove and the end pushes on the cup of the pin.
bob
What is this used for? I've never seen a reducing sleeve like this before.
Description says: MT Spring Grip Emergency Sleeve.
I've never seen one of those, but... I can see how it'd grip a damaged morse taper, the direction of the spiral means it would tighten up under load and the tang would stop it rotating in e.g. a tailstock?
Dave H. (the other one)
Here are 2 examples of a rarely seen tool. Who can say how they would set one up & use it? I have them & know what they are, but......I really am a NEWB.
Correct kd4gij! Hoping some can say how they would set one up & use it? I see a big grinder in my future.
This is on a surface grinder dressing from the bottom yours is for a too grinder and dresses from the side but same principle
