^^^^what he said!^^^^
I often hear people thinking the bigger the tool post the more rigid it will be, and this is a case of “forest for the trees”.
The tool post and holders will certainly be more rigid, no doubt about it, more is more.
But as the toolpost gets bigger, it also gets wider, and so do the toolholders. Add in a “more rigid” large toolbit and suddenly your toolbit tip is 50-60% further away from the center of the compound than it would be with the next smaller size toolpost.
All of this adds leverage against the ways and even though your toolpost if more rigid, you will actually induce chatter and other issues going this route.
It’s a bit of a head scratcher, but if you have run both large and small machines it becomes immediately apparent.
I spent decades running out large Moro Seiki lathe and when I tried to run my 5” Prazi it was a whole different ballgame .
Now that I have some time on this lil guy I have it dialed and can take much heavier cuts that I initially thought possible.
.120 D cuts are easy and with the right tooling and don’t stress the machine at all. Tiny lil compound, tiny toolpost, tiny tooling.
Here I go from 36rpm to 800rpm without no muss no fuss as I probably only have 5/8” stickout on the toolbit with the OXA toolpost, in 3/8”dia O-1.
Probably 2” stickout on the drill rod from the chuck.
