What is it?
silverhawk
H-M Lifetime Diamond Member
Dec 6, 2015
834
On a recent visit with my dad, he produced this "thing", and said it came from his uncles tool boxes. He was curious, and I could not show an expertise (my first guess was a turn signal indicator lever from an older car, but the inside button thing has me a bit baffled).
It is a long and slender shaft with a sharp point on one end (with a groove, likely to keep it in place), and a bell-shaped end on the other. That end has a round knob on the inside that feels like a spring is involved.
Does anyone have any clue what this might be to? I don't think this is an actual tool, but I've been known to be horribly wrong.
Joe
My first thought was a record player spindle with the point to find the centre hole easier...... but the grooved shoulder on those wasn't concentric, so you could put a stack of 33rpm vinyl and have it drop the next in the pile and didn't have to get up to start the next record.
Is the bell-shaped knob fixed to the shaft?
My other thought was a small centre punch if that back end could be pulled out and then released for a little percussive snap.
Brian
Brian
I could not twist if off easily (doesn't say much, really), not did I find a cross pin holding the two pieces together.
Sent from my SM-G970U using Tapatalk
These uncles worked on any machinery they had, so I am not surprised to hear diesel engines mentioned as the source.
I am also not surprised to have it identified this quickly.
But I am in awe of the collective expertise that resides in the group. Just, wow.
I would guess that if we combined the years of experience of the members of this group, it would exceed a million.
Most diesel engines have a thick wear sleeve on both ends of the crankshaft. Some can be a challenge to remove with the seal housing in place. I ground some of the Cummins injector plungers into small cape chisels and I would use one to cut a groove across the wear sleeve, carefully cutting the groove deeper until the sleeve would snap then slide it off the end of the shaft with an O-ring pick.
There are a couple centre punches in there as well.
