I’m a little late getting to this thread, but sometimes life (and work) gets in the way.
Who is this SOTPM guy? While it may not be PC, I say guy because I have never worked with a lady in the shop, however I have met some ladies in the office that are the equivalent in their world.
A number of years ago I had the pleasure of being a maintenance supervisor in a manufacturing operation, primarily metal stamping. Eight of my crew of ten all had traits that made them SOTPM, all of them were machinists / tool&die makers. Any of them could repair the machines, including electrical. Not one of them had a formal education or apprenticeship in machining. I never had to tell them how to do a job, all I had to do was ask that it be done. Made my life there pretty easy. The other two required a babysitter and weren't SOTPMs.
So what are these traits?
As said above they were intuitive. But maybe more importantly, they all took ownership of a problem and solved it. If they didn’t know how to do something right off, they figured it out. I never heard the words ’’I don’t know how to do that’’. If one of them came to me with a problem, they also normally had a solution for it also. I encouraged all of them to think on their own. It was very common the hear ‘’what do you think about this, or what if we….’’ 95% of the time their ideas and solutions were better than anything I could have come up with quickly because they had thought it through. All of them had confidence in themselves, were not afraid to try something new, and not afraid of failure. You learn something from your failures; you learn what doesn’t work!
If you are listening, machines ‘’talk’’ to you. They will tell you when they are happy and when they are not. The machine could be a small lathe or a large production line in a factory. Most people can learn to listen to the machines; some people just have the natural ability to interpret what the machines are saying, others can learn. Some will never get it. It’s all about actually caring enough to listen.
The above is true whether you are operating a machine tool, driving a car, or flying an airplane. One of my most interesting experiences in an airplane was flying with a guy in his C182. He had no idea what the airplane was doing. He could takeoff, cruise, and land, but could not feel the airplane. IMHO, scan your instruments, but in VFR conditions you fly a light airplane by feel. He had memorized all of the checklists and tables and was flying the airplane by-the-book. There were no natural movements on his part. I never went up with him again. The machine should become an extension of your body.
The average non-mechanical person looks under the hood of a car and sees a mass of stuff and their mind can’t break it down into the components, and has no idea what anything does. (and I’m not talking about modern cars where you can’t even see the engine under all of the plastic). The mechanic looks under the hood, and sees a number of interconnected systems and (hopefully) understands how it all works and can mentally break it down into the individual components. This is the result of experience, training, and a desire to actually learn what is going on. Most times when you break everything down, it’s really pretty simple.
One of the simplest and also maybe most difficult thing to understand is that all machines are the same. Shafts turn in bearings, gears mesh, things are bolted together, screws have mating nuts, if it slides it needs grease. Every mechanical machine is no matter how complex is composed of only three simple devices, the wheel, the lever, and the incline plane. Every mechanical device is a derivative of these three simple items.
If you’re not one already, how do you become a SOTPM?
- Look at the problem, and then think it through. Take the negative view, what could possibly go wrong, and then plan for that.
- Break down a problem into its smallest parts; solve each piece of the puzzle as needed. Things become simple once broken down.
- Don’t be afraid to try new ideas. As long as it’s not going to damage the machine or you, then go for it.
- Don’t be afraid to fail, if it doesn’t work then you learned what doesn’t work. That will set you on a new thought process.
- Have confidence in yourself. See above
Most people can get there if they want to.
