What Did You Buy Today?
saw this and was wondering about using it
Too coarse for the 2-56 that @Bi11Hudson wants to check. The specs don't give any dimensions of the tips, but I don't think you be able to get much below 20 TPI, if that. Clamp-on fixtures for calipers are handy (I have a set of cone-end adapters for measuring C-C distance between holes permanently attached to a low cost set of digital calipers).
A set of thread wires should get bill down to measuring 48tpi with a normal mic.
Below that I am unsure, something specialty I am assuming.
My Fowler and Shars 1" screw pitch mics have a set of anvils for 64-48 tpi range. So much nicer than wires, triangles, etc. They run around $75 for the non-digital style. I only use the tumbler-style digital ones at this point and keep a thread pitch chart in the case for quick reference.
Bruce
My Fowler and Shars 1" screw pitch mics have a set of anvils that for 64-48 tpi range. So much nicer than wires, triangles, etc. They run around $75 for the non-digital style. I only use the tumbler-style digital ones at this point and keep a thread pitch chart in the case for quick reference.
Bruce
Much nicer than fumbling with wires. I also like mechanical digital micrometers: easy to read and no batteries.
For small threads, I've been using a Shars thread mic. It works great, and most of my threads are <1". For the few times I need a larger thread, I use something like these..
They hold the 2 wires on the mic, so you aren't trying to juggle 4 items. It makes using wires not require 4 hands, which is nice. Not as easy to use as a thread mic, but good enough for the few times I year I end up using the wires.
Needed a set of pin gauges.
These will partner with my Starrett and Mayhew pin punches.
And I wanted a dial indicator with a 2” travel.
Finally, I’m a sucker for Perfect Handle screwdrivers.
Rick “not just buying lathe parts” Denney
I had bought 4 cheap import T-slot nuts on eBay. I received them today & I was horrified at the poor quality. The eBay Seller must be selling the Quality Control rejects.
This time I bought four quantity USA made T-slot nuts. This set me back $19.64 for 4 of them, including tax & shipping.
I always make my t-nuts.
I use some special material as it's the only thing I've found that puts up with the daily HARD use without deformation or cracking.
Chinese ones strip, te-co ones crack.
At those prices I should be selling mine on ebay! :O
