- Sep 8, 2019
- 4,360
Erik, please let us know your technique (cleaning, heating, etc.) and results!Three fluid ounces of Super-Blue with a landed cost of $14.60. I have never used this before, but I have always wanted to.
it gets a 4.6 rating on Brownell's websiteErik, please let us know your technique (cleaning, heating, etc.) and results!
My local Cabella's carries that and I've been considering it. Thanks.
Brian
Thank You !Security Measure
www.ebay.com
So you have the PM ER40 set tru chuck, if this is correct, can you relate as to whether a person can achieve a .120 offset with that chuck?You really need to get a by 32nds set for ER40s. Collapse range is 1mm and you really don't want to do that to your good collets. 1/16" is 0.0625, which is over 1mm. So a standard by 1/16" set will have holes in it.
I have the Shars 5" zero set ER40 chuck. Sorry I have no idea about the PM version's offset. Sounds like a lot of adjustment. I machined my own back plate for the chuck. I only needed to barely touch the chuck zero set screws to zero it in. Honestly don't recall what the adjustment range was. If your set up needs 0.120" correction sounds like something is pretty far off.So you have the PM ER40 set tru chuck, if this is correct, can you relate as to whether a person can achieve a .120 offset with that chuck?
no, i need to repeat a drilled hole with a offset with in the .120 range from centerI have the Shars 5" zero set ER40 chuck. Sorry I have no idea about the PM version's offset. Sounds like a lot of adjustment. I machined my own back plate for the chuck. I only needed to barely touch the chuck zero set screws to zero it in. Honestly don't recall what the adjustment range was. If your set up needs 0.120" correction sounds like something is pretty far off.
Ok. I will let others answer if they know how to do that with a set true. Seems like a lot of movement for a set true.no, i need to repeat a drilled hole with a offset with in the .120 range from center
yes, i am aware that a four jaw would do that, but it would really slow me downOk. I will let others answer if they know how to do that with a set true. Seems like a lot of movement for a set true.
A four jaw could obviously do this, but you asked about a set true ER40.
