What Did You Buy Today?
Not quite tools, but for a tool and included a little tool. Got some connectors for my ELS project. So the connectors are for the ELS for my lathe. Got some GX style connectors, and an interesting M8-4 pin connector. The cable end of the M8 connector has tiny set screws to hold the wires in. Each cable end connector came with a tiny 0.89 mm hex wrench.
I removed the hood/cover from the cable end, so you can see these screws.
Looks like it will clamp onto 20 awg wire, easily, which is fine for what I need. Who knows what kind of wire retention force that tiny M2 set screw has.
J
Just goes to show that a "brand" name isn't always the best.
Those are definitely counterfeit. I never buy Mitutoyo from Amazon. Never.
If you want Mitutoyo you need to buy from a reputable USA seller. Amazon is not a reputable seller.
The piece on the left...
...is an 'anvil'. It mounts to the bench with the slot in the bottom. The vise swivels in the anvil... there is a locking handle on the opposite side to lock the swivel.
-Bear
To expand on this a little, on the bottom of the jaws is a hole that can hold a pipe/ bar to the floor for added support if needed. Just using the slot in heavy application can be problematic.
They are a cool vise and work great with a little common sense. Hopefully some day when I get back to a larger shop I can get mine set back up.
