The rear shaft goes in an AXA holder.
Let us know how that works out.
I'm thinking for the quick and dirty you could set the broach with a shim behind it in the bushing at the full-stroked position and measure the height from the back of the bushing to the edge of the broach. Take a caliper set to that dimension and set a jaw on the ID of your pulley/work and scratch the other side to mark the depth of the keyway.I just got this Shars No 00 Keyway Cutting Broach Set.
I'm using it to cut a keyway in a 3/8" bore with a 3/32" key. I believe the shim is only used for the 1/8" key, is that correct?
