Boy when that thing grabs as it is breaking through is going to be interesting.
I wonder what the weak link will be if the 3 HP motor can’t provide enough torque to keep the drill moving. This really makes the case for pecking, proper RPM and lubrication.
I have spun an R8 collet (actually an integral shank end mill holder) before (or perhaps the motor belt slipped); the seal between the collet & the spindle (or perhaps the seal between the motor belt & it’s pulleys) was the weak link. Here is what transpired:
After doing this many times: 1-1/4” HSS center cutting square end mill on a plunge cut going through 3/8” of 6061 aluminum & then immediately continuing through 1/4” of A36 steel.
After about a half dozen of these plunge cuts (with CF!), the end mill went through the aluminum fine but soon after it got into the steel, the end mill got hung up and the end mill did not rotate while the motor was running for the short time it took me to turn off the drum switch for the motor. I did *not* have a set screw for the keyway in the R8 collet before going in to this operation.
Writing that out leads me to believe that the motor belt slipped, but I’m not sure because it happened so fast. After the mishap, the end mill was still mated to the end mill holder. It seems to me that if the R8 collet spun then this would have necessitated re-tightening the set screws on the end mill holder.
*However*, after the event the cutter was no longer dug into the steel.
*I don’t understand what happened*, but at the time my impression was that the R8 collet spun in the spindle. Perhaps I was biased toward that impression because I knew that there is no set screw for the keyway in the collet.
I often spin the belt on my 1 HP lathe. I just turn off the motor as quickly as possible, & she always starts back up fine.
