What Did You Buy Today?
Cutest 3” (80mm) bench vise. Found it in my parents garage.
Looks ugly but the jaw movement is really smooth. Will be a nice restoration project.
David,
How's the surface grinder coming along? I have that dresser too.
It’s all back together but I haven’t used it since reassembly because I ran out of way oil. A gallon of oil accompanied the diamond dresser so now I’m good to go.
I’m also in the midst of building bathroom cabinetry so there’s a bit of a logjam in the shop.
In September, I bought some 100 mm diamond discs for around $1.90 each from Aliexpress. Might be an alternative, if you are willing to wait for delivery. Mine took about 6 weeks to arrive. I got 14 discs, 7 different grits for $43.88 including shipping. They seem to be the same 1mm thick discs sold just about everywhere. Diamond lapping discs
I stick my discs on with magnets buried in the Aluminium disc. Make sure you recess them at least 1/2mm or the hole fills up with crud too quickly.
You also need a drive pin near the shaft. See Stephan Gottswinter.
Slow... you are really looking for a gear motor. 400-1000 rpm or so works. I had a pile of big DC motors, so mine is DC. ;-)
Sent from my SM-G892A using Tapatalk
In making some bushings recently, I realized that my 9/16” drill was junk, so I replaced it. I always grind 3 flats on my larger straight shank drills so I decided to buy a set of 5C collet blocks. I don’t really need them as I have at least 2 other methods to do the job, I just wanted them!
I got amazon gift cards so I will buy the wheels and the motor and other parts so that will be easy.
