- Nov 27, 2012
- 7,970
Oh, no- don't use casters. That's not just a no, it's a hell no. If a locked caster swivels around on you (like they always do) you might just feed your hands to the rotating belt. No, you want a steady, solid pedestal for your belt sander. Pull it into position by grabbing the heavy part and dragging it on two of its legs. Set it up so one leg points straight towards the operator, then put your foot on that leg while running your sander to keep it from walking away. Casters have their place, but this application ain't one of them!
I’ve been wondering how to deal with my belt sander because I’d like to roll it to the overhead door when grinding. A trio of locking casters should do the trick.
Edit: even just carrying the thing the ten feet would be fine
Uh oh Pontiac, that's exactly what I am doing to my belt sander but a bit different than just using casters alone. I'm mounting my belt sander on a bench grinder stand but I'm using a HF mobile base. I snagged 3 more of them before they excluded the CM brand from their 20-25% coupons.
The HF mobile base is to be used with wood for the frame but I use square steel tubing. Has adjustable feet to raise it off the 2 casters in the front. First one I used was for my 3 ton arbor press. It's heavier than my belt sander & I roll the arbor press out of the garage everytime I need to work on my truck, has been holding up fine over the years.
My little brother told me when the Wen bench grinder stands dropped down to $20 shipped on Amazon, I bought 2 of them. I'm glad you pointed that out about using casters cause that's what my lil brother is going to do with his but not sure what he's mounting on his. We both bought ours like 2 yrs ago & still haven't used them yet lol. I went & bought the square tubing a few weeks ago & bought the alumn plates last year so hopefully I'll get around to building mine very soon.
