Few shop additions. First is a Fowler brake caliper micrometer. Couldn't resist for $17 including shipping off eBay.
I have an upcoming project that involves cutting a helical gear. The two mating gears will meet at a 90, so need to cut the gear with the cutter at a 45 to the blank. My plan is to cut it on my Tormach 1100 using the 4th axis tipped at a 45. The CNC will move the X, Z and A (rotation) axis in synch. At least that's the plan. First step was picking up a Grizzly 7" x 10" tilting table. I'll make a base plate for the 4th axis, tip the plate to a 45 and tram it on the mill. Still waiting on the 0.7 mm Module gear cutter from an eBay seller in China. Hopefully they haven't developed a cough.
Last was a set of thread triangles from HHIP. Somewhere around $45 including shipping. I have a set of thread wires and multiple sets of Shars screw pitch micrometers. The mics are my go to, but wanted to try the option of triangles on a digital set of mics.
OK, in summary, not a fan of triangles. Probably my lack of dexterity and experience. I found them VERY awkward to position on the thread and rotate the micrometer. I'll fiddle a bit with the hole size on the rubber piece on the spindle which may help. Problem is the triangle wants to rotate (naturally) as the mic is adjusted. Might help to jam the ends into a Styrofoam peanut for stability like I do with thread wires.
Accuracy was also a problem. Probably operator error on my part as the triangles came with no instructions. The triangles have three different flats on the corners. Presumably for different coarseness of threads as the triangle faces should rest on the thread face, not the root of the thread.
I slipped the triangles onto the mic and ran the flats into each other, then zero'd the mic. Started with the sharpest edge.
Used a stock 5/16"-18 cap screw and measured the pitch at 0.24705". The included pitch chart shows a 5/16"-18 thread at a range of 0.2752" - 0.2691" depending on the class of thread. I checked the measurement twice, mic is working fine.
I moved to the middle of the road triangles, re-zero'd and remeasured. Got 0.25055" this time.
Lastly, went with the coarsest flat and got 0.26095".
I measured the same bolt with a Shars 0-1" mic and got 0.272" which is dead in the middle of the screw pitch range for a 5/16"-18 bolt.
I'll do a little Google research on triangles as I can see their value. The measurement error is in my initial zero'ing of the triangles. I was zero'ing off the flats which will naturally give a different result for each coarseness as the flats of the triangle are the surface doing the measuring, not the flat on the edge. I guess for now I could zero the mic on a known thread and use the delta to zero to measure where I'm at. The screw pitch mic's are still #1 in my book. More to follow as I learn how to use the triangles.
Bruce
