Some enlightening numbers regarding your moisture content and proof your equipment will be “happier” by adding an aftercooler/water separator to the system. Assuming the 7.5hp is a recip compressor and had no ”aftercooler” before and discharging air out at 190 deg F at 116psig and making @ 25cfm and your ambient is 90 deg F. The moisture content can be calculated as: and (assuming my math skills are still intact, lol)
Moisture content without aftercooler
discharge temp 190deg F = .0035 lbs H20/ ft3 free air (ACFM) or .056oz
comp is 25cfm x .0035 lbs H2O/ft3 free air = .0875 lbs or 1.4oz per minute
avg run time 15min x 1.4oz = 21oz or 1lb 5oz or .164 gal per 15 min runtime
Moisture content with aftercooler (assuming 90 deg ambient + 20 deg F approach temp of the aftercooler)
New discharge temp 110deg F = .00045 lbs H20/ ft3 free air (ACFM) or .0072oz
comp is 25cfm x .00045lbs H2O/ft3 free air = .0112 lbs or .18oz per minute
avg run time 15min x .18 = 2.7oz or .17lbs or .055 gal per 15 min runtime
Essentially it’s almost 8 times less moisture in the system
.18oz vs 1.4oz per minute run
2.7oz vs 21oz per 15 min run
only way to reduce it more would be by adding a refrigerated or desiccant dryer
