What Did You Buy Today?
Recently purchased this 1987 Massey Ferguson 80hp, 390 4x4 tractor with a heavy duty 8 1/2' plow blade to use this winter for my plowing. Will be putting the Ford backhoe in the shop to rebuild the engine, turbo, and most of the hydraulic cylinders. Mike
A tip, on those chains -
I plowed snow in northern New York state with a Ford 555 backhoe, with cross chains like that.
I learned to hate them after a while - They shifted under load to wind up between the tire lugs, offering little traction.
The answer, is to set them up with a center chain, connecting all the cross chains together, around the tire circumference.
OR, bite the bullet, and buy a set of skidder chains, with the rings between the cross chains - You could go for the whole enchilada, and get the LUGGED rings - Unstoppable, then.
Can be a mite hard on a paved driveway, though :~)
I know what you mean, but the chains on the tractor came with it and with the four wheel drive, and near bald tires I think they will work okay. I run double the normal amount of cross links on the 755 and they have no issues, and leave them on year round as it never leaves the property. Those skidder chains are fine on rough terrain, but they get old fast on any kind of packed surface. Mike
FYI. I HATE COMPUTERS!
Me too! I recently replace my old desk top shop computer with a decent laptop. I still haven't adapted to the laptop keyboard & finger pad/mouse. I bought a separate mouse, much better. But there is no feed back on the keyboard. No sense of a bit of a click! Then there is the non-standard key arrangement. Kind of kills touch typing.
The Ford was 4WD also, but that didn't help much with those miserable chains. It did have a heated cab, once I rebuilt the heater :~)
It didn't help, that the people I worked for were cheapskates - There were very limited resources to work with in that place.
The machine had an 11' plow, that I had to weld back together, to be usable.
The roads where I used it probably could have been called "rough terrain" - I would have given anything for a set of skidder chains.
I had 3 miles of dirt / rock (I can't call it gravel, because it was mostly bigger rocks) road to plow, out to the county road, and it snowed a LOT.
There was one place on the road, where there was a little rock cut - The problem was that the cut exposed a little spring in the side hill.
By the end of the winter, the spring had built up a 15-20º side slope of blue ice, tilting toward a 10' bank, to a rock filled creek.
I always had my heart in my mouth, doing that stretch - I found I could catch it just right, by hitting it fairly fast, on the uphill side, and just make it through, with the machine side-slipping the whole time. I called that area "The Glacier" ..........
Trying not to ask stupid questions that I already know the answers to...
but...
Why does everybody like tables full of holes? Yeah, yeah, clamping, right, got it- there are hundreds of ways to do that which do not involve proprietary accessories to fit those holes. I have a 5 gallon bucket of Vise Grips and C-clamps that I've collected for 30 years that say there's nothing that can't be built on the floor or a unholed table. So please, take a look and tell me if CertiShat is a fashion trend, because it sure looks that way to me.
I have a 4 x 4 x 3/4 table that I plan to drill on a 4" grid one of these days. It has a 4" overhang and I do prefer to use the table corner as a square and clamp to the edge. It would be nice to clamp in the interior of the table for the 4th corner of a frame instead of tacking it down. The other big use for me is I would be able to dog things down without having to work around the clamps!
I have 25 of the HF F clamps, I'll sacrifice 6 and cut and weld stock to the end for the holes. I don't really like to jig things up unless it's necessary. If I need a pair or a few sets, I'll tack the first one down and build the others on top of the first one!
I have a 1/64th set of 5C collets, most were a NOS stock sold by Enco that were made in Taiwan and seemed to have minimal runout. There were a number of 1/64th increment collets that were missing and I purchased ones from Shar's many years ago, but they were just OK and a bit rough as well as poorer TIR compared to the Enco ones. The specifications for acceptable TIR 5C collets in general is not that good unless you are buying premium ones from companies like PBA, Royal, Hardinge. Recently there was an eBay listing for most of the 1/64Th increment 5C collets made by Royal, all new, so I decided to buy them to replace the Shar's collets. At around $8 a collet, seemed to be a good deal. Looking at the Royal product site it seems like they are no longer selling these 5C collets. Comparable Crawford/PBA 5C collets are $30+, Hardinge are 2-3X more.
Any left, link? I have a 32nds set and would like to fill it out.
