What causes this finish on 6061 aluminum?
The lathe gods have smiled. After reading all the replies it made me do a lot of checking and it turned out to be the bolt that the motor pivots on was working it's way loose. Tightened the bolt and the finish improved tremendously.
Thanks again for all the ideas and the help you were to me.
Another thing to consider, especially on the smaller 9 x 20 lathes, is to check the pre-load on the spindle. The manual says something to the effect that it was done at manufactering.
I read that the best way to check for preload (providing the bearings are still good) is to 10 Remove the drive to the spindle, 2) give it a GOOD spin by hand, and 3) It should spin only 1 1/2 to 2 turns. If it spins more than that, It's worth trying to increase the load on the bearings. The spiral pattern only indicates that the cutting tool is cutting in a spiral. That's what it is supposed to do. Best of Luck.
