- May 4, 2015
- 3,583
Well newbie , your learning start watching some YouTube's Mr Pete Tubalcain . Or barrow some shop teaching books and start reading about lathe tool cutters and shaping and sharpening of them. Carbide lathe bits come brazed on strong steel support to fit holders . Insert tools use carbide tips . With many steels when torch cut they harden and some need annealing. I had a job making hold downs for a planer for a shop I worked in . I had a lathe and mill in my garage and a bandsaw to cut stock. The company ordered the steel when I got it it was so hard even grinding was tuff. They sent it back after annealing the steel worked beautifully. I would bet about 1/4" will need to be turned before it's past the hardest edge. You can anneal it yourself usually by heating up in a coal fire then just leave it till all the coals and steel are room temperature. It's kind of a big piece to practise with but we use what we have. Find some aluminum to practise tool sharpening and making. Different metals at times need different angles and shapes.
Good luck and keep turning
