- Jun 29, 2014
- 4,065
CNC Gang Tool Lathe - think something like an OmniTurn.Welding table looks good. Very similar to what I built.
Big question is.... what's the project???
Very cool!CNC Gang Tool Lathe - think something like an OmniTurn.
Thank youWell, I have access to a laser cutter at work + offcuts/can purchase at cost. My cost is about $115 for the 304 3/16" material. I did the CAD in Draftsight and essentially we can just dump the dxf on a thumb drive and take it to the machine. No programming time needed.
The total cutting time for this sheet size and thickness was about 15 minutes. Multiply by (insert shop rate here) a shop rate and you can take it from there. However, if you go laser or plasma you should consider that you will get some slag depending on the shop and their programming and shielding capabilities.
Our laser can do 1/2" mild steel with some slag when cutting with shop air, it's pretty clean with Nitrogen - at that thickness you start to get warping. I would seriously consider water-jet over laser or plasma for that thickness.
I think you would be looking at close to two-three hours of cutting time of a sheet that size.
Couldnt believe how much things move when they are welded.
One of my early jobs out of high school about '75 was working for a rice grower. They had an ancient rice huller that they decided they were going to rebuild. It had been shut down in the 40's and the whole thing was a mess. I got the job of making one of the elevators so had to fab the base and the head. They were mild steel sheet with angle iron frame. Basically big metal boxes that would contain the shafts and drums for the conveyor belt with bolted on scoops. I had never done it before and all I had was OA, ancient arc welder and an abrasive saw. No jig table, no saw horses, no grinder, nuthin.Couldnt believe how much things move when they are welded.
