I've been ready to buy a welding outfit for years but I keep chickening out because the only experience I have in welding is H.S. shop class (spot welder) and - many years ago - using someone's oxy-acetylene torch to cut a big piece of metal in two.
Now I'm back to wanting my own but don't know what to get. Any chance on starting a thread that covers MIG/TIG/Oxy/MAPP/Plasma and anything else I might encounter out there? Kind of like the CNC thread that starts at 0 knowledge?
If not - then how about a simple suggestion for me. What is the cheapest and most efficient for my particular needs:
1. I want to build a few (4) woodworking lathe rests - basically a metal bar or angle iron with a notch ground on it, and a round bar goes on that notch. The weld has to be super strong and since woodturning is a zen thing, it's got to be pretty.
2. I would like to be able to rough cut some big things - maybe once a year - but I'm scared to keep a giant tank of oxygen around because 1) I know it will be 10 years before I empty it and I don't want to be stuck with an out-of-date tank that nobody will fill and 2) I live in the desert and I'm paranoid about things that can get hot and go boom.
3. I want to be able to heat-treat some tool steel for plane blades or home-made chisels. I've got a small propane forge but want something bigger/faster.
4. I have an ATV trailer - the el-cheapo Home Depot type with the big swing-down ramp on back. I want to cut that ramp (I could use a saw) down to size, weld square tubes along the outside and make sides that would drop into those tubes so I can use it to haul bigger stuff to the dump but lift the sides out when I don't want to use them.
5. I don't have any neighbors but just in case, I want to be able to take all the ugly rusted stuff laying by the shed and if I get a neighbor that pisses me off I want to weld it all together into a 12' tall piece of cr@p that I will call "art". Something hideous, I'll probably paint parts of it dayglo orange and fluorescent pink and it would be made of a mix of mystery metals so I need something capable of welding steel to aluminum to wrought iron - clean or rusted.
6. Weeks from now when I've learned all I can about welding and am the world's expert on the subject, I want to try and repair a woodworking plane that has a crack. But unlike every single other such repair done in the last 100 years, I don't want it to look like someone dripped bronze brazing all over the thing and tried to smooth it down with their teeth - I want a perfectly invisible repair in cast iron. A repair so clean and precise that it will take a team of scientists with electron microscopes to find the repair.
Oh - I want to do it all for less than $300 if possible.
thanks
Joe
thanks
Joe
