Thanks Dan. No rest for the weary! BTW what's a bar? LOL.
FYI for everyone reading this thread... Silver soldering would not work in this case. There was very little metal contact area between the fitting and metal cover. A ring about 0.020" wide to be precise. Silver soldering, like all soldering requires a fair amount of mutual contact area for strength. I went for TIG Silicon Bronze. Very good for tight localized heat. I was also going to braze the inside only for appearance reasons but could not get my stubby TIG torch in there and lay a complete bead. Ended up brazing it with a continuous bead around the OD of the fitting. This will also give it added strength from the vibrations on a motor vehicle. Don't want the oil line/fitting coming off!
