- Jun 26, 2018
- 1,726
Ok, no matter what chuck I use nor what drill rod, hardened rod for CNC slide etc.... I always have this weird run out. I can use a independent 4 jaw and get it dead nuts...but if I rotate it enough, it will at some pattern, gain/lose .001 to .0015 of run out. I marked the pulleys to see if all of them were aligned every so many rotations, if it could make the perfect storm. Being that the spindle it v belt driven and I even loosened it a bit.....I didn't think so.
What could be at the heart of this? Turn a full rotation, dead on, turn it 3 times, a bit of run out. Now it's a workable amount, but I just gotta know why so I can sleep better. It maybe futile, but I'm sure I'm not alone in the need to understand this thing. If I'm not using an independent chuck, this is now .003 to.0035, not where I want to be.
