Now I waiting for some new fans to cool the drivers. I have a heat shrink connected to the drivers but they sure do get quite warm. I'm still trying to figure out how I'm going to power these. I had two fans installed and powered from a 12v power supply.
Congrats!
The two main things to remember about cooling are:
1. Drivers are going to get hot - let them
2. Orient the fins for the most efficient convection cooling
You probably don't need cooling fans - not that there's anything wrong with that. I build power amplifiers for radio that get extremely hot. Most folks would think that this amount of heat will destroy the devices. Not so. Just stay below 100°C (212°F) and you should be fine. Some devices can even operate up to 450-500°C.
The most effective thing you can do is provide the proper ventilation for the cooling fins. If you orient the drivers properly, the heat will dissipate. The only time you'll need fans for cooling is if you run the drivers very close to or at their maximum rated power, which is a bad idea to begin with.
The drivers should be mounted such that the fins and the spaces between the fins are oriented vertically so that the airflow is from bottom to top, since heat tends to rise. Also, they should be mounted so they are outside of the enclosure you're using. That way, convection will take over and you should be good to go without the need for fans. Again, that assumes you did not pick out drivers that are going to be stressed near their design limits. Convection works by heat rising and creating a slight vacuum under it, which will pull in cooler air from underneath. It actually creates a moving airflow, similar to a fan.
If you're going to block the airflow in any way, such as mounting the drivers internally or pushing the assembly against a wall or other obstruction, then you should consider extra cooling techniques.Another thing to consider is, if you've mounted the drivers internally, you might just be blowing hot air right back onto them, severely diminishing cooling efficiency, if you haven't created a reliable way to circulate outside, cooler air throughout the enclosure. So make an effort to mount them - the fins, that is - externally to the enclosure, in open air, or punch many holes in the enclosure, bottom and top, in line with the fan(s), to create the necessary ventilation for proper airflow.
None of this is to discourage you from cooling things the way that feels most comfortable to you, rather, just some info to set your mind at ease. Also, keep in mind that powering fans is going to put stress elsewhere in the system, so understand all of the parameters before you start buying and building.
