- May 27, 2016
- 3,479
Thanks for the clues about the gauge being a flow meter.Your regulator is actually a flowmeter. See the red line on the black scale? Set it to that number, and you'll have a good start. Of course, General Zod is correct about setting the argon to a minimum value for a clean weld for the situation you are in. The nice thing about the dial flowmeters is that you can set them with the torch off. The rotameters are actual flow gauges (the ones with the ball in them). You need to set them with the torch on.
I said don't use zip-lock bags. They are too expensive. Just the cheap sandwich bags with the flap are fine. The medium bags hold almost a liter. At 20 lpm, they will fill in a little less than 3 seconds. If you are really picky, you can inflate them in a full bucket of water and measure the water that spills out over the rim. If you are really tight on funds, you can pour the water on the garden or water the plants. This is difficult to do with a zip-lock bag, since it is hard to seal the top over the end of the torch. The zip-lock bags also cost slightly more.
OK - I get it now. You are inflating various size plastic bags while counting seconds, as a way of "measuring" the gas flow.
The flowmeter gauge units involved may still need a little detective work. I may settle for believing the numbers in black are litres/minute.
Available gauges and flow meters seem to have a ultra cheap sort, by post from China, around £8.50 to £12.00. Today, the rate is 1.39, so for USA folk, think around $11.81 to £16.68. Then there is a long gap, with the next cluster starting around £22 to £27 (about $30 to $38). From there, offerings are fewer, in £30 to £45 (about $42 to $62). The cheapo sort seem also to be mostly shiny chrome/nickel plated, while the more expensive ones have the "all brass" steampunk look.
I also see gauges with units kgf/cm2, which is a near approximation to bar. (1 bar = 1.0197kgf/cm^2)
