- May 27, 2016
- 3,479
I have purchased WP-20 size water cooled TIG torch, branded "CK-20". I have to hope that it is a good brand, because it cost a bit more than the China imports, though for me (UK) it was still an import. I had been happily checking out all the bits, and it has caused me some questions about pipe thread sizes compatibility. I will try and explain..
Start with pictures - always better for clarity
_ _
For my welder, the electrical connection is by the European-style 13mm "insert-and twist" thing with the lug on it, and no gas nor water comes out via the welder. Gas and fluid stuff is all elternal to the welder. The adapter to connect to the water return, while making the electrical connection is shown. The very same is used for the standard setup where the gas goes up the power lead.
In the CK booklet, it shows the gas goes in the black pipe, the water goes in the blue pipe, and the water return comes out the red, which is a combination water + electrical current pipe.
The adapter standard 3/8" BSP threads (that's BSPP, not taper sort) would the very same 3/8" shown in the CK blurb leaflet, and and first sight, look to be the right size - but they are not! The red lead female starts to screw on, about one turn, and then binds up. I guess I need either a different product, or some other thread adapter to get it coupled up.
Thus the questions..
What does "DINSE" acronym stand for?
Are the sizes something special to welding?
Are these standard across brands?
Is this situation something to do with a difference between USA 3/8" pipe threads, and UK 3/8" pipe threads?
I could use a little help figuring out what to get to put this kit together.
_ _
