i always payout a couple feet of wire to see how much bend I'm working with. If there's a lot of curl it means that roll came from the end of the batch. Good manufacturers straighten the wiring to keep consistant. I've run straighteners on the machine to see if I could get better tip life. To biggest problem I find with tip life and wandering is if the gun cable is looped, the wire will cork screw, that and too tight on the rollers and it causes a fine line in the wire making the wire act like a reamer as it cork screws through the liner. Arch wander I find is also related to a poor ground. if your using the typical spring loaded clamp, thats your problem. The best is the screw clamp style. Here's a good test: weld at 20.0v for 15 minutes. the heat in your clamp is telling you something. The more heat the worst your grounding problem is. I've seen the clamp start to smoke from the heat. Go to a screw type clamp, problem solved.
